TwinTurbo.NET: Nissan 300ZX forum - Yes, a ground issue. (n/m)
DVDBURN (MD)
on August 06, 2016 at 12:23 PM
What's the reason? Screws provide grounding or is more
posted by jzack
on August 03, 2016 at 04:09 PM
O2 sensor issues
Barry (NJ)
22:23:22 07/31/16
Did you reboot ECU after new O2 install? (n/m)
BarryGZX
01:46:45 08/01/16
Reboot the ECU(?)
Barry (NJ)
06:59:42 08/01/16
MAF or vacuum leak. MAF would be the first guess since both
jzack
08:58:09 08/01/16
Boost/Vacuum leak test is clean
Barry (NJ)
12:30:20 08/01/16
2 brand new sensors both being bad...doubtful. I'm
jzack
14:20:19 08/01/16
Low fuel pressure could cause whacky engine conditions
jzack
14:26:07 08/01/16
Checked fuel pressure, 40 psi at idle. (n/m)
Barry (NJ)
22:24:26 08/01/16
Just noticed I'm seeing 5+ volts from TPS
Barry (NJ)
18:58:15 08/01/16
TPS is a variable resistor acting as a simple
jzack
20:25:05 08/01/16
Disconnect your battery...
DVDBURN (MD)
21:16:31 08/01/16
Could the fact that there are only 2
Barry (NJ)
06:19:43 08/02/16
Panel? The ECU bottom cover? (n/m)
DVDBURN (MD)
20:17:53 08/02/16
Actually, I miss read your post...
Barry (NJ)
07:19:22 08/03/16
Ah, you mean the daughter board.
DVDBURN (MD)
15:05:03 08/03/16
jzack
16:09:46 08/03/16
Yes, a ground issue. (n/m) -
DVDBURN (MD)
12:23:40 08/06/16
Thought it might have been the SAFC
Barry (NJ)
06:18:15 08/02/16
Barry - did you figure this out? (n/m)
jzack
21:20:25 08/05/16
